HR20 thru HR23 CE Release 5/28 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
Window of opportunity to download:
Friday, May 28, 2010 11:00PM - 2:30AM ET
Saturday, May 29, 2010 11:00PM - 2:30AM ET
Risk Level for this Download: High Risk
New features
HD PPV no longer requires the HD Package!
Output resolution is no longer limited to 480 when HD Package is not purchased
Improved/Updated
Under the hood
Notes
This CE will remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
If you revert from CE back to National x3A8 you will lose the guide cache, recordings made after CE, recordings played back since CE, Series Manager entries and the To Do list.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
Version History
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:24:01 (0x03E5)
Posters everywhere!
DirecTV Cinema enhancements.
Systems in this CE
HR20-100 • HR20-700
HR21Pro • HR23-700
New features
Improved/Updated
Under the hood
Notes
Isn't that about Everything ? sheeesh.
They may as well say, IF you revert back to the old NR it will do a Everything reset ....
Multi room Beta Ended?
About two weeks ago when I turned on TV I got a message that the mutiroom beta test had ended. I went out of town and am now looking into it. From the forum it does not seem that is true. I downloaded the new software last night. When I go into the multiroom menu it states "I am not autorized to use this feature and I need to call diret tv to order." This does not make any sense. Does anyone have any ideas?
Yes, The Beta time frame has ended and D* has released it, it is available from D* for $3 p/m
HD DVR's
Is there a way to request the dvr series manager can hold more than 50 recordings... i would like to setup recordings for all shows i like no matter if the show is currently airing or not... that way when the season starts again. The recording will automatically start again. I understand this may cause more recording conflicts, but i will manage those
I believe that 50 is the limit.
That said, I have not heard any type of limit on the HR24, I know there is one, just don't know if it's the same.
CE's for Memorial Day Weekend
HR24-500 CE for the Weekend of June 4th
