0X104 now being rolled out to west coast markets. This enables the long-awaited ota tuners on the HR20!
Details forthcoming..
ABount dang time.
I hear you can only record 2 shows at once instead of 3.
This is disapointing news, yet good news that OTA will be working finally.
OTA is crucial to anyone wanting this thing. It will ALWAYS look better than satellite mpeg4 or not and there are many times when weather takes satellite signals OUT but not OTA.
I get Boston HD LIL over sat but live in market that gets PBS and CW that carries UConn games so I desperately need the OTA solution. And since the OTA chips on the HD Tivos are pretty lame, it dont get those channels very easily. My Windows Media Center tuner card gets them but I really wanted a more stable DVR solution so OTA is a must in the HR20. I want to take advantage of that 5th generation chip.
You are assuming that the ota tuner has an LG 5th generation chipset in it. The box isn't made by LG, so who knows who makes the tuner.
That particular antenna should go a lot farther than 25 miles.At under 25 miles away from your towers a correctly aimed Channel Master CM-4228 should be great. AND outside is always best.
Many people try the CM 4228 in their attics with success. If not then put it outside.How can I find an antenna that can get me local channels? I did get the new software update on my HR20 and would like to try to receive my locals via an OTA. My zip code is 92127. Will I need an antenna on the outside of my house or just in the back of my box?
Thanks . . .
Thanks . . .
Limited time offer
