HR20 / HR21 / R22 CE Release 0x0248 6/20 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
HR20-ALL
HR21-ALL
R22-100
Window of opportunity to download:
Friday, June 20, 2008 11:00PM - 2:30AM ET
Saturday, June 21, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! CE Release Warnings & Agreement
PLEASE READ THIS SECOND! CE Release Download Instructions
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
Improved
  • 01 - Stability
  • 01 - Accurate network connection status after reboot
  • 01 - Overall Media Share
  • 01 - Channel change speed
  • 01 - Tuning and Recording Robustness
  • 02 - Stability
  • 02 - Fixed incorrect blue background
  • 02 - Fixed R icon not displaying in Folder during recording of a event in Folder
  • 02 - Fixed unable to Clear Delete Marks in Folders in Mark And Delete Screen
  • 02 - Fixed unable to modify extension on single episode of a booked series
  • 02 - Fixed modifying extension of already booked series does not update episodes already in ToDo
  • 02 - Fixed black screen shown when blackout is removed
  • 02 - Fixed no Kepp or Delete On Screen Display OSD after FF4 to end, RW, Pause, then Advanced
  • 02 - Tuning Robustness
  • 02 - MediaShare – Fixed unable to play slideshow in PIG when browsing thumbnail
  • 02 - MediaShare – Fixed wrong song ordering
  • 02 - MediaShare – Fixed blank thumbnails
  • 02 - MediaShare – Fixed FF of pictures jumps back instead
  • 02 - MediaShare - Stability
  • 03 - Fixed channel banner program information being incorrect after using previous button
  • 03 - Stability improvements, including issue after deleting in response to K/D OSD.
  • 03 - Fixed recently searched keyword not saved in previous screen
  • 04 – Fixed stuck boot 1 of 2
  • 04 – Recurring manual records no longer share playlist folder
  • 04 – Faster deleting large folder from playlist
  • 04 – Improved history for manual records
  • 04 – Stability improvements
  • 04 – Fixed DIRECTV On Demand results list
  • 04 – Fixed issue where KEEP ICON is missing after using mark&delete
  • 04 – Fixed mini-guide with guide tip
  • 04 – Lipsync improvement
  • 04 – Media Share Stability
  • 05 - Added ability to send a Diagnostics Report back to DIRECTV - See notes
  • 05 - Added New Release category for DIRECTV on Demand homepage
  • 06 – Stability
  • 06 – Audio
  • 06 - Mediashare compatibility with Nero MediaHome
  • 07 - Recording robustness
  • 07 - Favorite List handling of hidden ATSC channels
  • 07 - Auto-recording titles with symbols e.g. Law & Order
  • 07 - Mediashare media access issues
  • 07 - Removed HDCP warning during HDMI negotiation
  • 08 - Stability
    [*]09 - Fix for unable to acquire guide after repeated setup
    [*]09 - Fix for loss of program guide
    [*]09 - Program information updating in channel banner when tuning from the guide
    [*]09 - Mediashare streaming video from the PC
    [*]09 - Mediashare thumbnail display when using page down
    [*]09 - Misc. minor UI tweaks
    [*]09 - Improved HDCP support
Updated
  • 01 - History messages for recording and deletion events
  • 01 - Close Captioning Left Placement
  • 05 - PC Mediashare is back
  • 05 - Faster category search and sort
  • 05 - Faster loading DIRECTV on Demand listing
  • 05 - Program Info Screen text
  • 05 - Stability
  • 07 - GameSearch
  • 07 - User Interface various issues addressed
  • 07 - Installer Dish Setup
  • 07 - Issues with rebooting
    [*]08 - GameSearch
    [*]08 - User Interface (various issues addressed)
    [*]08 - Installer Dish Setup
    [*]08 - Issues with rebooting
New features
  • 01 - Triple Tap support e.g. title/name/keyword search screens, favorite list naming, etc
  • 01 - Search for PPV Movies in guide options panel
  • 02 - 1-touch record hint for program cells/items
  • 02 - Add "Move to Top" hint OSD in the Prioritizer screen
  • 02 - Add a display settings option in the System Setup screen for the enabling/disabling of the 1-touch Record Tip OSD
  • 03 - Daily Fortune
Notes
  • 01 - This CE cycle is expected to contain new features
  • 04 – THIS DOWNLOAD WILL REMOVE GUIDE CACHE AND THE GUIDE ACQUISITION WILL TAKE LONGER
  • 04 – BOOT STUCK WARNING: If you could not boot with the last CE with network attached, and had to revert to national to be able to boot with network, do not try POKEEYENOW. If you try it, your HR20 will probably still hang/crash on boot. If you insist, then you will have to boot without your network and POKEEYELATER to correct.
  • 05 - Send Diagnostics Report:
    requires IAMANEDGECUTTER keyword search to be enabled
    *** Network must be properly set up and working to use this feature ***
    1. [*]Use the Menu+Info keys to get to the Misc Options screen
      [*]Select the Report option
      [*]Click on Send
      [*]Wait for it to finish
      [*]You will receive a confirmation key in your response.
      *** Please include this key in any post you make in the issues thread ***
      [*]Please note that you can only send one report per 24 hours
      [*]If you do not have a network connection, you will not have this option
Showcases is now called "Movies Now! & More".
Sounds like they are getting ready to use their showcase feature for possible pre-recorded PPVs? Then again, it may just be to promote the On Demand training-videos.
Still losing picture on recorded programs when hit the right button for widgets. Widget bar comes up to a black screen.
Successful downloading on my HR20-100 of version 0x248 with no issues to date. Recordings were uneffected..
Cheers,
Robin
For what it is worth, I did not sign up for the widgets program. I downloaded the CE Friday night and hit the right arrow for fun and a bar showed up and said widgets coming soon. It had 4 or 5 icons on it. I did not lose video though, the bar was semi transparent over the playing channel.
Good,
Then you can take my place, I did sign up and still don't see anything when I push the correct arrows, not even the coming soon banner.
Jimbo
Good,
Jimbo
Jimbo - they're working on some issues, not sure if it is related - but hang in there and check it again in a 2-3 weeks :)
The widgets forcing the screen to black (or gray) only happens when watching buffered/recorded programming. When watching live video, the widgets bar appears and does not affect the video. Either way, audio is not affected.
I'm not a widget subscriber, but downloaded the CE. No issues encountered. . .all seems OK. I'm glad the HD audio synch got fixed awhile ago. . .that was annoying when watching the Nascar Prelude to the Dream PPV event.
H21-100 & H20-600 CE Release 0x407C 6/20
Screen Centering Function on HR20-700
