HR20 compared to h10-250 | SatelliteGuys.US
donnie0328
27
I got my new hr20 yesterday. I had one problem watching a recorded show. At the end of the show the receiver locked up instead of asking if I wanted to keep it or delete it. I did a reboot and seemed to fix the problem. One question I have is will the shows still record with the receiver turned off, since it does this when you hit the directv/tv off button. sounds like the unit is still on (which is a bit loud, but can live with) but no lights. All said unit seems to be good compared to the h10-250.the tivo model looks like it found programs farther out then the hr20 is.
It takes 12-24 hours to fully load the guide in the HR20 upon being fully installed and activated. You may want to check you advance listings again later today to confirm you now have more (2 weeks worth).
upgrading to a hd
Question about category sort
