Time for another update (maybe, 90% chance of it happening). See http://www.dbstalk.com/showthread.php?t=80351 for more details.
wow
this is getting more and more like we gettting new virus definitions everyday ... lol
Yeah, it would be nice if the backdoor to force-download was easier. I want the bug fixes, but the 11-1 window is rough the next morning... my HR20 takes about 40 attempts before it starts downloading, roughly 45-60 min.
at least my virus scanner auto-updates itself.
jpn,
If you are having trouble getting your HR20-700 to download the updates regularly, and you are doing the numbers right at the beginning of the blue screen.
Try unplugging the unit and do the numbers when the blue screen comes up, I have had to do it that way a few times and it seems to work fine doing it that way.
Jimbo
If you're pressing the enter key that's your problem, enter only the number and nothing else.I have not tried skipping the 'enter' key, will try that next time.
Sorry, I mis-typed. The original instructions I read was to use the sequence '0 2 4 6 8 Select'. I have been doing that, not skipping the 'Select' button.
Limited time offer
