HR20-700 vs. HR20-100 | SatelliteGuys.US
hdmore
11
Are there any differences between these to boxes and if so what are they?
Thanks,
Mark
Really not much, I think the biggest differences an external antenna for the RF remote control, two ethernet ports (only one active) and both coax and optical digital audio outputs. The HR20-100 also tends to get software upgrades a few weeks later then the HR20-700.
The 700 is said to run much hotter than the 100 and is physically a larger unit. The 100 has a known unfunctional RK antenna also. Still, I like my 100 and like the fact that it runs fairly cool.
Robin
Although my 700 runs at 122-127 deg. F, that hasn't appeared to cause any problems (I have had it for 9 months).
My 100 runs from 100-107F, pretty subsantial temp. difference for high end electronics that are suppose to be basically the same unit. Makes you wonder what accounts for this variation, ventilation?
Robin
USA HD looks great
what do I get; what do I pay?
