HR10-250 connection ? | SatelliteGuys.US
jguy
46
Does anyone know if using the HDMI out fron the HR10-250 disables the optical out?
I am current using the HDMI from the 250 to my HD TV. I am in the market for a digital audio receiver and dont wanna spend the money to get one with HDMI ports. I just wanna make sure I can run the optical from the 250 to the audio receiver and the HDMI from the 250 to the TV. Also is their any consensus on how much better, if any, HDMI is better than component for video quality? Thank you for your time.
I use HDMI for video and the optical out for audio with my setup. Also, I can't tell any difference between HDMI and component on my old 1080i rear projection set.
ok great, thanks for the reply. Anyone else have any input?
You can use either of them. I went from using the component outs and optical to the HDMI and having my TV output the optical and never changed a setting and it still works.
Dr. Emmett Brown says........
Directv Activation...Alternative Methods vs. Telephone Line
