HR 34 Double Play | SatelliteGuys.US
HR 34 Double Play
bb83
574
95
Missouri
Is there a way to pick what turners are on double play? If I am recording on 1,2, and 3, can I double play on 4 and 5. How do you switch the turners you are double playing on?
There doesn't seem to be any way to directly switch tuners from the remote, unless you pull up the Channel Banner bar. There could be some sort of trick play that I don't know about with the remote, but as far as I know you have to use the Channel bar to get to the PIP controls.
John
HR24-100 vs. HR-24-200
Receiver auto on?
