priester68 SatelliteGuys Pro Original poster Sep 18, 2008 305 0 Natchez, MS Sep 26, 2008 #1 I consider myself luck that my HR 20 works fine. No problems at all. From what I've been reading, some people aren't so lucky.
jcrandall Proud Staff Member Staff member HERE TO HELP YOU! Apr 3, 2005 11,054 456 Central Michigan Sep 26, 2008 #2 Remember that there are hundreds of thousands of these units out there, the problems always speak louder. I own 3, and I've had to have one repalced, it happens. In the two years the HR20 has been out, the software has improved significantly, almost like a totally different product then when they launched it.
jtwex SatelliteGuys Pro Jul 25, 2008 828 0 Embarrassed Bear Sep 26, 2008 #3 Jason Crandall said: In the two years the HR20 has been out, the software has improved significantly, almost like a totally different product then when they launched it. Click to expand... Amen to this & hope the same is true for the HR21's.
goober22 SatelliteGuys Pro Sep 10, 2004 490 7 Panama City / FT Walton Bch, FL. Sep 26, 2008 #4 Yep, you usually only hear the complaints. I have 4 HR20's and have never had an issue with them. Most folks only post when they have problems, not when all is well. I'm happy with mine and have OTA capabilities as well.
Bob Nielsen SatelliteGuys Pro Aug 22, 2006 1,721 0 Bainbridge Island, WA Sep 26, 2008 #5 My HR20 has been flawless. My HR21 missed a few recordings with one of the early firmware versions, but has been without problems for several months. Even Tivos occasionally had hiccups (I had a hard drive go bad after one month).
charper1 Bourbon Tester Supporting Founder May 18, 2004 18,442 6 I'm Nationwide Sep 26, 2008 #6 Ditto, the sentiments above; mine are flawless.
grydlok Vuvuzela Horns Pub Member / Supporter Aug 11, 2004 2,519 0 Richmond,VA Sep 26, 2008 #7 Fast approaching 2 years on my 1st HR20-700 next month
