HR-20 Remote Control Volume on Denon 3806? | SatelliteGuys.US
drwindmill
55
Hello, is there anyway to control the volume on my receiver without toggling the switch to AV1 on the top of my remote everytime. It is annoying.
There is a way to do it (I have my HR20 setup this way), when you are setting up the remote in the HR20 menus, read the options very carefully, it is not worded or described well, but it is there. I just kind of played around with the different options until I figured it out. I would give you more specifics but I am at work, I am sure somebody with a photographic memory or sitting at home right now can probably give you the exact steps to take.
This is the way. I found it on another site.
Yes, there has to be a tv code programmed to the tv device, then:
1. av1
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 3
4. press SELECT
Any MLB "adjacent market" fans lose RSN's, too?
no NFL Super Fan??!!
