How we can improve the signal strength | SatelliteGuys.US
baiju_vb
Hi ,
We are looking for a solution on this following matter .
Actually we have data service through dish ( only retrieval ) .
We hv Televees 1.6 m dish with 270m long cable (RG11 - Beldon 8213 ) with
1 line amplifier (SMW ILA 17-21 db , Freq 950 – 2150 Mhz) . There is no way of reduce the cable length bcos of internal pblms:) and amplifier kept after 100 m . Bcos of the trunking there is no other place to connect the amplifier . As normal every 75m require a amplifier but in our case that not possible . And offcourse the signal stregth & level very poor .
How can we improve this signal strength .
we need your valuable suggesions .
tks
You have an unworkable configuration. I presume the problem is trees.
Not enough detail about your circumstances to help. WhereTH are you? Alaska?
It's hard to believe you can't put more amps in there. Solar-powered?
What kind of terminal equipment is this? Normally I would say do all data collection remotely and for back-haul use a packetized network, rather than high-freq.
If you can't amplify it, you need a bigger dish. 2.4M is about the biggest you can buy before costs really escalate. It wouldl more than double the signal strength.
Is Fox Sports en Espanol Blacked Out On Channel 407
Dish 622 Some TV2 Channels are Snowy
