?? How to set up LAN U-Verse gateway ?? | SatelliteGuys.US
Fulton
Fort Worth, Texas
:) I fixed the problem!! Norton Protection center was preventing file sharing.
:confused: I called U-Verse to get help to set up local file sharing and they said they could not help me. ( I had one before using a AT&T DSL with my own Lynksys router.)
For some reason I just can't get the file sharing to work. All PC's connect directly to internet threough the gateway. I tried to set up a LAN following the XP instruction for my situation with all PC's connecting directly to internet through a resident gateway.
I would appreciate help if anyone could talk me through the process of setting up a local LAN.
Thanks,
Fullton Cook
Saginaw, Texas
Thanks,
Fullton Cook
Saginaw, Texas
Is your gateway a router ? May have to experiment with turning off Windows Firewall ?
Wyr
Any good or very bad Comcast stories?
Question about Digital Box DCT 2224
