How to properly reboot a 721 | SatelliteGuys.US
120inna55
1,454
31
Athens, Texas, United States
I know that pulling (then replacing) the card on the 721 causes a reboot, but I also see that pressing the power button and holding it for about 8-10 seconds results in a reboot as well. Is pulling the card somehow better? It would seem that pulling the card could eventually lead to a scratched/dirty/defective card, whereas holding down the power button would be more benign. So why do so many people (including tech support) tell you to pull the card for a reboot?
Reinsert card means cold boot, while pressing power button - warm. Probably you are familiar with the two methods of reboot, if not - just one example: warm reboot doesn't eliminate resident virus if your PC infected.
I prefer the turn off the switch on the power strip method usually on the once a month lockup.... (usually my fault when I string together too many remote commands at once)
E*'s CSRs strike again!
Is "SUPERDISH" a Super waste of effort?
