How to move to 118 | SatelliteGuys.US
How to move to 118
Ilyago
7
:confused:from 148 if I have toroidal dish with
Reversed Polarity Circular Dual DSS LNBF and DP DishNetworks receivers #311?
Thanks,
Ilya
Not gonna work. You need a Dish 500+ or buy a used Superdish and the repoint kit.
Landlord doesn't want even talk about dish replacement.
There are no heads for 118, which I could install to T-55?
I've supposed that dish itself doesn't matter and problem in the heads – different frequencies, etc.
What about receiver?
Thanks for answer!
Ilya
About T-55
Maxx Electronics Corp. :: Learning Center :: Toroidal Super Dish Antenna Setup
Toroidal Features
• Same effectiveness of 55 cm (20 inches) dish for each LNBF installed
• Can accommodate up to 8 LNBFs
• Covers up to 40 degrees in arc (60 degrees in azimuth)
• Multi-beam Antenna uses Toroidal Formula , is designed to reflect signal twice through the main reflector and sub-reflector
• Receives many satellite signals simultaneously using only one dish
About heads:
Wave Frontier M20R
Wave Frontier M20R
Model: Wave Frontier M20R
This LNBF is designed for T55 Toroidal Dish:
- Dish Network(61.5W, 110W, 119W, 148W)
- DirecTV (101W & 119W)
- Bell Express Vu (82W & 91W)
- Dual Output
- Frequency Range: 12.2 Ghz - 12.7 Ghz
- Noise Figure: 0.6 dB
Product# M20R
[back] brief info
Price US $49.99 US $45.00
You can't use that dish, but if the mast is 1 5/8", pop the T55 off and slide on a 500+ or 1000+. You may have to add struts to support it.
I recently had a customer that was on 61.5 with a Dish 300 legacy. She needed to be migrated to the 118 bird. She only was receiving International programming.
A buddy of mine said to use the dish 500+ and just run the 118 to her receiver and keep the switch from the dish.
I wound up installing the Dish500+ and a DP33 becuase she upgraded her receiver to a 625 and only had 1 coax from dish to receiver.
Can you repoint a Dish 300 to 118?
Will the receiver get software updates on a single dish pointed at 118?
118.7 is not a DBS-class satellite. DBS sats are high-powered and transmit from 12.2-12.7 GHz. 118.7 is an FSS-class satellite, meaning it's medium-powered and transmits from 11.7-12.2 GHz. 118.7 is also the only FSS satellite that uses circular polarization (other FSS sats use linear polarization). You need a 30" dish minimum as well as the unique LNB that is only going to be found on the Dish 500+/1000+ dishes.
you will need the b20r lnbf from wavefrontier:
118/119 LNBF-REVERSED
LNBF Frequency: 10750
Input Frequency: 11.70GHhz~12.75Ghz
Output Frequency: 950Mhz~2150Mhz
Dual Output
I have one on a t-55, works very well
VIP612 Video/Audio Glitches
DP34/311/121 help
