Depends, some locals will grant them. I managed to get 3 of 4 to agree. You don't lose anything for trying.uWILLknow said:If you can get your locals that are "assigned" to you - based on you exact physical address - you most likely will not get you waivers approved.
korsjs said:don't every make a change to your locals. once you switch you won't get them back. the dish csr have been known to mess things up and you can't get them back once they are turned off. don't even ask dish about locals. leave it be and pick up your true locals with an antenna.
korsjs said:don't every make a change to your locals. once you switch you won't get them back. .
BigFella said:Thanks korsjs - OTA is impossible (too many mountains between me and the transmitters) so I get my locals through basic lifeline cable (Comcast). It would just be a little cheaper and more convenient if they both (locals and distants) came from Dish. That said, I'll heed your advice (I've read it many times before in these pages) unless someone can offer a sure-fire, risk free alternative.
Limited time offer
