How to get firmware version on 811? | SatelliteGuys.US
rrolsbe
25
Where does one look for the firmware version number on an 811 Dishnet HD receiver? When I view the sys-info screen, I must not be looking in the right place.
Thanks Very Much In Advance
Later
Ron
make sure your on the sys info screen - menu - 6 - 1 - 3 on your remote.
pretty sure that is where you are so..
beside where it says software version, that is your current firmware version.
it doesn't just say 2.xx it will be something like 2xxxxx-N or something... but you should be able to figure it out.. i'm not around the 811 right now to get more specific.
Can I tell Dish to shove it and still get local OTA?
SatelliteGuys Member makes the news
