How to gang up receivers | SatelliteGuys.US
roosman
34
5
Hi Again
I want to be able to use either my coolsat or twinhan to tune signals. The coolsat will be for feed hunting/blind scanning. The twinhan will be for HD and 4:2:2 etc.
Will this work
LNB ----> Coolsat --->Twinhan
or is this better
LNB ----> Twinhan --->coolsat
Do I leave LNB power set to on on both or do I shut off the lnb power on one of the units?
Use the Coolsat to aim the dish and tune signals.
The 1st option is the better of the two....or get a dual LNB and run a line to each tuner
Leave LNB power on. The PC card will only see the same polarity as the Coolsat when the CS is on
Help!!!!! Need FTA Church Channel in Ohio
Galaxy 16 at 99, tp 12.189
