Hello Guys
I have One LNBF dual Circular that one pin Conector (where you put the rg6 cable) is un-welded..When I tried to disconect my RG6 cable the conector pin was broken (un welded ) ..
I have tried to check any way to open the LNBF unit to weld the Pin but I can not see any screw or something like that..Maybe is by Pressure but I am scared if I could broken the Unit.
. at least One Size is Working
I know that you will tell me Buy another by $10 bucks but If is Possible to fix I can do it..
How I can Open The LNB? I think that Most Of the LNB's and LNBF's in the market are the same desing (Unable to open easy)..
My LNBF is something like that
