How to factory default the 522 remote? | SatelliteGuys.US
justthinking
47
Does anyone know how can we factory default the remotes that came with 522 Receiver?
I want to know how to restore factory default in case the SAT portion of the control got screwed.
Also, I would like to blank the memory so the other 3 set of controls (TV, VCR, AUX) can be blanked.
Also, I am having problem with the program guide, the local channel portion of the progamming guide
only shows up to 1 hour in advance anything beyond that shows information not available.
Anyone know how to get the programming guide to retrieve all the information include
the local channels so I can schedule the recording properly?
As for the second part with the locals, I had this problem too. Try this:
First, hold the power button on the front of the 522 for 6 seconds (until it shuts off) and allow it to reboot itself. If, during this process after acquiring the signal, it downloads a new program guide, it should have a fresh guide with all of the local information. If it doesnt...
Go to Point Dish (Menu > 6 > 1 > 1) and do a Check Switch. Once that completes, exit out of the menu screen and it should acquire signal and download a fresh guide.
If neither one of those downloads a new guide, try unplugging the 522 for a several minutes and then it should download a fresh guide.
811 OTA Problem
Difference between 5.0 and 6.0 remote? (Other than UHF)
