How to copy Wally recordings to a new Hard Drive | SatelliteGuys.US
Is there any way to copy from one hard drive to a larger drive. I only want one drive.
I have done this using two already-Dish-formatted 1.5TB disks for my VIP receivers... I have no idea if you can do this for the Wally that has a lot more folderol on it to store the guide, the buffer, and possibly other stuff I don't even know about.
How big a disk do you want to add?
Not so much about size vs procedure. On Hoppers, or any other system with a built in hard drive, you can move from external to Hopper to new drive. I've done this a couple times and currently moved from a 2 TB to 4 TB on the Hopper. My Wally has a 1 TB and I want to upgrade to the 2 TB. But where does one temporarily store as you move from one to another ??? I have a feeling it can't be done.
My Wally has a 1 TB and I want to upgrade to the 2 TB. But where does one temporarily store as you move from one to another???
You don't. You use a computer running LInux to move programs from one hard drive to another.
Don't give up! I have never done this for a Wally or 211, so I don't know for certain. But I recommend trying the following.
  1. Attach your new 2TB drive to your Wally and let it format it.
  2. Detach again and plug it into your PC runing Linux, letting Linux mount whatever partitions it finds. Familiarize yourself with the partitions.
  3. Plug your old 1TB disk into that same PC running Linux and look around. You are looking for the programming folders. Once located, copy them (as root!) to the new 1TB disk.
  4. Let us all know how it goes. :D
Do you have any hard statistics on how long it takes you to transfer content of a given size between internal and external drives? I've done that dance quite a few times, but I avoid it as much as possible because it is so interminably slow.
Hopper 3 MoCA Questions
Dish, get your 4K S*** together...
