How to connect (VIP 222K to dpplus lnbf) | SatelliteGuys.US
dfernander
2
florida
Hello everyone,
I hope I can find some help with this. I use to have dishnet a few years back but I gave it up.
Now I just got the package (with HD) which includes a VIP222k (dual) receiver and a new dish. The dish has a DP Plus digital LNBF with connectors labeled 1, 2, 3, and LNB IN.
How do I connect the receiver to the dish? The manual only shows the connection to the Dish Pro Plus separator, but I'm not sure which connection(s) I should use on the DPP.
Thanks for your help!
Connect wire at lnb at 1, 2, 3. Connect that wire inside to the one side of separator that has just one coax connection. On the side that has two coaxial connections connect each of those to the two tuners on the 722. Do a check switch by going to Menu, 6, 1, 1 then selecting switch then test.
Remote Access problem.....receiver offline
No Local Channels - Day 5
