How to change time zones on 722? | SatelliteGuys.US
dhadik
10
Pennsylvania
I'm sure there must be a simple solution, but I haven't found it on any of the menu's or in the manual. How do you change time zones on the 722? I have it in my RV and would like to have it set to the time zone where I'm located instead of stuck on EST. Thanks for any help.
It's based on your zipcode.
If you're traveling, you could call in whenever you've changed timezones and give them a new "service address" with a zipcode in the new timezone. A variation of the "moving" concept. This would also allow you to get local channels assuming you're under the appropriate spotbeam.
Unfortunately, if you have other receivers that are not on the road with you, doing this would cause them to lose whatever locals they're getting.
I must admit I'm very surprised. But if that's how they want it...
It makes perfect sense (from Dish's standpoint). Officially, receivers are supposed to be used where the account has them listed. Also, no need to worry about users setting the time zone (or time) wrong.
Advice for new customer on getting best deal?
Lose satellites almost every night
