How many remotes? | SatelliteGuys.US
How many remotes?
Depends when you got it. They only shipped with 1 remote in the beginning because they did not have TV 2 active at that point. Once they activated TV 2 functionality (or maybe just before that) they started shipping with two remotes. If you only got 1 you can likely get Dish to give you another if you call and ask for it. Worst case they can be had on Ebay pretty cheap. The 32.0 remotes are the only ones that will do RF with the 922, but any of the legacy remotes will work fine in IR mode as long as you enable it (in the menus).
saucerman,
If you would PM your account number to me, I would be happy to get you a second remote. As lakebum431 stated, depending on when you received your 922, it dictated how many remotes were included with the 922 receiver. Thanks.
Timer not scheduling
Need DIRT assistance
