How many EHD's on Hopper | SatelliteGuys.US
You can have 2 at a time for playback and at least 5 for transfers.
Sent from my iPhone 4S using Forum Runner
Unpowered EHDs can be connected to a port or a hub on any of the 3 built-in ports. I would not try having more than 3 active EHDs. The 3rd can only be used for transfers in or out as there are only 2 (Externals 1 and 2) in the menu for playback next to the DVR red button.
The 3 can all be run at the same time and hub or port does not seem to matter. That assumes hub is not speed limited like a keyboard only USB1.0 is. Then again I doubt USB3.0 is a help over USB2.0, so far. Buy USB3.0 if the same price IMO.
-Ken
Question above: have you had more than 3 transfers at once? Guess I should try. -K
Yup. Worked fine, but it's not a function that I'll be using everyday :) . I mostly just have 1 or 2 at a time hooked up.
So I can put the two EHD's I have on a usb hub on one of the usb inputs on back hopper and my usb OTA tuner on the other usb input
Cheapest package that includes the RSN?
Watching recordings from joey
