How Do you find 61.5 with a dish 1000 | SatelliteGuys.US
kds64
225
Arizona
How do you find 61.5 with dish 1000
my zip is 85542
i put an lnb where it said 119
but still can't find it, i dont have i dish 500 or dish 300:confused:
the dish 1000 gets 110, 119 and the 129 sats. If you need or want to get the 61.5 sat you'll need a second dish (300 or 500) and probably a DPP44 switch if you want all four sat locations.
I tired to use a dish 1000 with a dish pro adapter arm so it would be centered in the middle and the signal strength was much lower , than using a dish 500 with a dishpro adapter arm. I don't recommend using a dish 1000 since it is made to receive 3 sats.
VIP-622 Question
HD signal strength test
