When is it going into stand by? It will go into standby overnight with the daily guide download and reboot, even if you have it disabled.
I have mine set for guide download at 3 am (default) and have an Auto Tune timer set for each sat tuner a 4 am to wake it back up. Otherwise, it would be asleep every morning.
Sounds like a problem there tiger. Mine doesn't do that, but also mine didn't get the software upgrade either. I guess Dish doesn't love me anymore. I'll have to go find some "Direct-TV" love, since they have gay stations like Logo.
Because going into standby deletes the buffers.Why do you not want it to go into standby?
I see. Now that you mention it, after I changed the menu setting to disable the inactivity standby, the only time the 622 would go into standby is overnight.When is it going into stand by? It will go into standby overnight with the daily guide download and reboot, even if you have it disabled.
Thanks. That works. Tried it last night.I have mine set for guide download at 3 am (default) and have an Auto Tune timer set for each sat tuner a 4 am to wake it back up. Otherwise, it would be asleep every morning.
I only set one Auto Tune. That was sufficient to wake up the 622 Why do you set two? Are there 2 specific channnels that you want to have full buffers in the morning?
Limited time offer
