How Do I Know | SatelliteGuys.US
How Do I Know
dmann304
24
I go to ch 499 and still see a searching for sat signal for B-Band signals.
Is this normal still untill they roll out the HD stuff?
Check channel 498. That will tell you if you are getting a signal from the new satellite.
I get a little of everything. 480 gives me a "searching for signal" message. 481 tells me my B-Band is working. 498 earlier gave me the congratulatory message, but not has the "searching for signal" message.
That is what I get... I guess if you get the slide on ch 498 you are OK?
More of same
From Little Rock, AR I have 499 not available, slide on 498 and BBC confirmed working on 490 and 491, I'm going to assume this means i'm ready to go, when they are.
At least we got one new channel
replacing HR10 ?
