How do I get CBS HD East & West? | SatelliteGuys.US
So, give E* a call and see if they will activate, if not actually call my local CBS affil.? I know they have a waiver request on E*'s site but I assumed that was for SD, not HD????
I don't think you can get both! East is on Sat 61.5 and West on 148(I believe). I think you will have to choose one. DO NOT GO THROUGH CSR's --- Go directly to Dish Tech by going thru the menu to add channels. The CSR's ALWAYS screw this process up and the tech's are from the US and are extremely helpful. If you have distant CBS, you should already have the waiver and it usually takes about 15 min. Sometimes it depends how far away you live from the local CBS signal.
Good Luck.
625 DVR pixelation?
Perfect Vision Flat Panel reviews
