How do I connect 4 dish without using DP44?? | SatelliteGuys.US
choudhur
5
I have Super Dish (110, 119 and 121). DP 34. I am trying to connect Dish 500 to
get VOOM. How do I connect Voom satellite ( ???) using DP 34. I am trying not
to buy DP 44 to connect 4 satellite. I have a extra DP21. Thanks for your HELP.
Run the one of the outputs of the DP34 to one of the inputs of the DP21 and run one of the outputs from the extra dish to the other input of the DP21. Remember that you will need to do this for each satellite tuner that you will need 4 satellite locations for.
What would the settings on the receiver look like? Can I use a Standard 4X1 switch?
DISH 1000 Install Problem - HELP please
Which Installer Would You Recommend?
