how do I attach 2 LNB's to one dish arm? | SatelliteGuys.US
dfecarter
491
39
Connecticut
HI,
Was wondering if anyone has had success mounting 2 LNB's on to the same dish?
I have a 4' fortec offset dish, wanting to attach my CK1 LNB WITH CONICAL SACLER and my Ivacom KU LNB next to eachother. Why you ask, well am thinking I'll get superior KU results from that LNB compared to the combo. Galaxy Mktg sells a 2 LNB bracket but with my conical scaler I'm thinking the two won't fit side by side. Any such experiments/experiences to share?
HI,
I like your avatar ! I've got a couple cat ones I could use !
Thanks! Appears to be just what I needed! I did order the Scalar sidecar kit. Will let ya know if it works eventually.
still having problems setting up my motorised system
reputting together a 90cm fortec dish
