I know there has to be a good reason, but how come Dish won't carry the PBS stations in available HD?
I am not sure I understand the difference between carrying a local Fox Station in HD and a local PBS station in HD.
A large percent of the funding for local PBS stations is completely local. It's not run the same as the Big 4 nets. It's hard to explain how it's different. One thing is a large amount of the stations are run by schools so E* would need to deal w/ both the admin of the school & a budget office, then the station itself.
Then how is D* and the local cable companies able to deliver PBS in HD? They most certainly would have the same hassles but succeed in having PBS in HD.
Also why no HD of the local CW station? I'm in the Philly DMA.
Ron
PBS transition to HD involved creation of 4 channels in their alotted digital spectrum. Instead of the standard allocation of one HD (x.1) and one SD (x.2) carrying the same conent, PBS chose to add local content SD (x.3) plus Spanish SD (x.4). This mash up changes by location, but all have four x.x channels.
PBS would not agree to Dishnet carrying just two channels - SD and HD. PBS demanded Dish carry all four channels. Dish did not have the resources available to carry all four, so PBS said, no HD for you.
PBS was the real loser and in a later contract allowed DirecTV to carry just the two channels carrying the same content. As PBS renegotiates Dish contracts, Dish has been and will be granted the HD and SD only carry rights.
Ron
PBS in OKC has several OTA subchannels, but the Cox Cable HD feed comes directly by fiber from OETA, so the PQ is pristine. I'm sure they could do the same for other providers (for $), but the OTA folks are SOL. I remember the days when the OETA OTA HD channel was the national PBS feed, with no subchannels. That was wonderful.Keep in mind, that 4 channels in one frequency slot means no HD. You can call it HD, but it ain't.
they have NJN, WNET,WLIW and some Channel in New York (Plus channel 25 in New York). Thats 4 HD signals or 16 SD signals depending on the time of DayKeep in mind, that 4 channels in one frequency slot means no HD. You can call it HD, but it ain't.
Many DMA's (i e New York) have more than 1 PBS station in HD..New York has atleast 4
See this is a lot of the problem. Since PBS isn't run the same as the big 4 then it is much more complicated than dealing with those. Where I live now PBS runs 1HD channel and no subs at the moment. The station still has markers set to run a 2nd SD channel & maybe a marker (never used) for a data channel. Where I lived 6 months ago they were only running 1 ch. Where I lived about 4 yrs ago they ran 1 HD & 1 SD. So it' isn't quite as simple as dealing with most national networks.
Limited time offer
