Hours of HD | SatelliteGuys.US
Hours of HD
The Home Media Center is a bunch....found it
The Home Media Center HD DVR gives you up to 800 hours of storage space in SD, 200 hours in HD, so you don't have to delete shows you want to keep to make room for new ones.
The HR20 I dont know as its not listed. Depending on the hard drive size its either 50 or 100 hours of HD
I have a HR20-700 and a HR24-200 on my main HDTV so I'll look at it as 50 and a 100 hours That should cover all my shows but I'll add everything up before I record it all. I just hope the guide goes for 10 days.
Thanks Guys
Jack
I perfer to think in this way: ;)
HR20 300GB
HR21 320GB
HR22-24 500GB
HR34 1TB
Don't forget DTV reserves 100GB of the hard drive for their use. ie: vod, ppv etc
So theoretically the following would be available space.
HR20 200GB
HR21 220GB
HR22-24 400GB
HR34 900GB
edit to fix caps lock goof:)
HR20 200GB
HR21 220GB
HR22-24 400GB
HR34 900GB
At least they are not as bad as Dish Network, I read (although I am not sure, so correct me if I am wrong) that Dish reserves 1TB of the Hopper's 2TB drive for "their use," plus 500GB for PTAT, leaving 500GB for "your" use, that is pretty ridiculous if you ask me, if that is how it is.
I still can't get over how much content the HR34 holds. We record a ton of shows with the 5 tuners, and the box only started deleting older shows today after having it installed for a month.
What Equipment
MLB Extra Innings
