Horizontal Video Shift/Judder on New 722... | SatelliteGuys.US
nathan118
37
I just got my Dish installed yesterday, and so far I'm pretty happy. I'm seeing a strange video shift (which I think is only happening on HD channels).
Specifically today I've seen it on ESPN HD. I'm on the west coast. On the Point Dish screen it says:
Dish System: 500
Tuner Input: 1
Transponder: 7
Satellite: 110
Locked - Echostar 110 West Signal Strength: 62
It happens very intermittently....maybe once or twice every minute. There is no breakup at all, not like a compression problem, but instead the entire image shifts sideways by maybe 20 pixels and then goes right back. It happens very quickly.
I don't think it's a playback problem, I think it's being pulled down that way. I've tried component/hdmi and it's the same. I rewind and the studder happens in the exact same spot.
Any ideas before I call my installer back? Any other info that would be helpful?
And now I haven't seen any problems for the last half hour and watching on various channels. :)
Guess I just have to get used to some of the quirks of satellite tv.
That's a problem, you should call dish support to report it. If you press pause, can you see the issue clearly through a slow forward?
If it is happening on all channels, I'd say it's an issue with cabling or the receiver itself.
OTA Antenna Mounted on Dish 500 or Mast
DN and Home Network
