Hopper3 install .. no lnb swap | SatelliteGuys.US
beachfront71
7
Newport Beach, CA
Hello and thanks in advance..
Upgrading to hopper from 3 622's.. Sat Dish is WAY up there and they could not swap lnb due to space issues w/ ladder..
They mentioned there is a switch/device they can use instead of lnb swap .. it is the same switch/device you install when you have more than one Hopper 3...
My question is .. does anyone see any performance issues with going this route if it works ...?
If it doesnt work .. plan b may involve scaffolding .. I am on a hill...
Yes, it is the same switch (DPH42 switch) that is used for more than one Hopper 3. I have not heard anything on performance difference going this route.
Reactions: Tampa8
Hopper3 gets confused playing recording on second Hopper3
Hopper remote operate Samsung Q7?
