Hopper3 HDD swap | SatelliteGuys.US
Hopper3 HDD swap
bogieman1958
2
Lamar,SC
Set up is a Hopper3 and Joey 2.0, both are purchased units (in 2017). Have given great service, but the Hopper is starting to get a little glitchy when viewing and/or fast forwarding through recordings. Also, accessing recordings through the Joey gets buggy at times. Haven't found any recent info on replacing the internal HDD. Can it still be done? and if so what procedure is required?
I'm one of those odd guys that like to own and install my own stuff. Does Dish still let you install your own stuff?
When I was using Dish, I had a couple of hard drive failures. The net of it, for me, was that the Seagate ST2000VM003 was the only drive that the H3 would recognize, per this thread:
Maybe they've changed the firmware by now to recognize additional drives, but I wouldn't bet on it.
I did the replace twice. It's just a couple of screws, pull off the cover, take out the drive caddy, and replace. An easy fix. When you boot back up, the new drive is recognized and formatted.
I just got a purchased hopper 3 replaced from Dish by just paying $15 shipping charge. The house power went on and off a few times and damaged the board on the Hopper 3. Unit has a Toshiba hard drive with a manufacture date of 7 2013. Hard drive still functions fine but the Hopper 3 outputs no HDMI video outside of Hopper 3 starting up Logo. The replacement Hopper 3 shows up as purchased on my account. I am thinking about removing the hard drive and pulling the contents off since it was about full. I might just install it in the replacement Hopper so I can just move the content to an external drive.
Reactions: charlesrshell
Probably your 2nd plan might be better to get reliable transfers, It may take a long time to move each one to an EHD but in the end they will be more reliable IMHO
get yourself a good panamax surge protector to!!! there a real life saver i belive there warranty is upto 10 million for anything hooked up to it that's damaged
I just checked and the warranties on the various Panamax surge protectors are up to 5 million. That's still pretty good for a normal home enthusiast.
I received my replacement Hopper 3 today. To my total surprise it was brand new! I was sure there were no more new ones. It says new on the box. Here is a picture of the HDD that is in the receiver. HDD manufacture date is Dec 15, 2023. I didn't get a picture of my other Hopper 3 that failed but it had a Toshiba HDD Manufacture date of Jan 2013. Board failed on the other Hopper.. HDD is still good
Is it us, or is it them? (Hopper or network?)
Joey keeps freezing
