Anyone else get it?
The year ain't dead yet.I thought back in the spring it was said the next release would have some level of Hopper tuner/timer integration. We have had at least a couple of releases since then.
Too bad I can't check the Ver # from Dish Anywhere.
On Dish Anywhere, got to settings, then receivers. The software version is listed there.Are you sure? I am able to see the version number of both my Hoppers with Sling on Dish Anywhere.
Thanks. Both at 506.On Dish Anywhere, got to settings, then receivers. The software version is listed there.
I just checked mine from Dish Anywhere. I'm still on S506.Too bad I can't check the Ver # from Dish Anywhere.
Limited time offer
