Got S309 on my HwSs last night, from what I saw, didn't seem to fix any of the S308 bugs.
My OTA signal strength meter is broken on my HwSs and my Hopper 2000s. Have to go to the channels and press INFO to get the reading.
Sent from my iPhone 4S using Forum Runner
I am still having trouble with no sound while watching a recording from one of my Hoppers. It was working good all morning then started to act up. If I select a recording from another Hopper the sound works OK. The sound works from a headset that is connected to the composite RCA ports and from a Bluetooth headset. Performed a red button reset to get the sound working again.
Sometimes you can start over the recording and it will fix the sound issue. Pretty irritating though, doesn't seem like S309 fixed anything at all!
Had same problem again this morning only from one same Hopper. I noticed the sound issue only happens on recordings since the 1am update. All recordings before the update the sound worked as normal. This one Hopper is the only one that the sound goes thru an AV receiver if that has anything to do with it for some reason. I did another reset and all is normal now. Sound works good on all recordings
I am told the only thing S309 fixes an install issue when doing a new Hopper install. Nothing else different between that and S308.
Hold onto your wallet. your Dish Hopper fees are going up $11 more on 5/22/2013 unless plans change.
I noticed in the View Counters menu at the end of the list remote controls that are paired to the Hopper show battery voltage. Is this something new for S309?
Limited time offer
