I have s230 and it's as fast as ever
cosmo_kramer said:Agreed. Is it me, or are the tiles now a little smaller??
lucky86 said:Are they slow to respond to the front panel buttons as well? If not, verify the remote isn't in IR mode and try de linking and re linking.
3HaloODST said:40.0 remotes don't have an IR mode for the sat receiver.
Sent from my iPhone 4S using SatelliteGuys
False, go to the remote manager in the menus and choose IR and then enable.
DWS44 said:Don't think that's the case. That setting is just to allow the Hopper to accept IR universal remotes, like the Harmony remotes. On that screen, it states that the Dish remote continues to use UHF, even if the setting is enabled.
eddwall said:It is not the command that is slow, it is the response of the Hopper.
Example: You are on a channel, from remote you change the channel. You can see the new channel on the header, but your screen is black and the new channel does not appear for a few seconds. The actual picture & audio are delayed from coming to the TV.
Limited time offer
