Hopper stuck in "starting learning mode" for remote programming | SatelliteGuys.US
kevinsickles
171
2
I am trying to program some additional commands to my remote 40. When I click on "learn" the Hopper gets stuck with a message "starting learning mode, please wait..." I have placed the remote next to the antenna and waited several minutes. Also, I did a hard reset, It did not help.
Any thoughts?
Thank you
Kevin
Not sure, Was programmed a while ago, I tried the option to erase all existing commands and start learning from scratch. That also fails.
I would start all over and use Menu-Settings-Remote Manager-DVD and then search for you dvd player. The programing that you are trying to learn may already be there.
I was ready to give up, but figured what the heck I'll try un-pairing. It would not un-pair using the hopper un-pair, Had to use the 5 step manual commands on the remote, Re-paired and it worked! Thank you Charles and Satguys!
ION TV timer doesn't work, well recording anything on ION doesnt
Does the hopper have IR eye on the front?
