Hopper Reset Button | SatelliteGuys.US
Hopper Reset Button
TechWriter
376
99
Is pressing the Hopper reset button the same as cycling power to it?Have any other Dish receivers had a reset button?
No, it's not.
Pressing the reset button only resets the software. Power cycling will reset both the software & the Hardware.
Is there any "practical" difference between the two?
For example, when would you Reset and when would you pull the plug?
I agree with that.
I can't speak to the Hopper, but every prior receiver I've had (not counting the 301 which never needed tending), the 508, 721 and ViPs behaved differently with holding the power button vs pulling the plug. Pulling the plug was much more effective.
Protection Plan - how much?
Saving Recordings On DVR625
