Am I able to copy the recordings from old hopper to new?
Using an EHD won't copy over any PTAT recordings but the method given by DISH support will.Or dump from old to EHD and then to the new.
That big of a transfer, you want to do in small groupsthe only problem with this, as I tried to do the transfer last week from HWS to HWS with ethernet...is it takes forevah!
The 100mbit ethernet transfer speeds...well it's 100mbps. I had 729 shows (all of Worlds Dumbest, and all of Married with Children)...plus a couple oddball movies. Estimated that it would take around 2 days of transferring...then after I started it, it quit without any reason in hour 2. I didn't try again and just said "**** and other adjectives"...
I've done a number of BIG transfers--but H and/or H3 to external HDD (when needing to repalce the DVR), and gotten great results with reasonable time that seemed surprisingly short/fast--NOT days, but hours, sometimes estimated something like 8 or 12 or a few more hours if hours. The only problem recordings when attempting a transfer are PTAT recordings, even those set to save as a single show/recording, but that has LONG been a known problem/limitation. Other than that, tranfers to external have always benn sucessful.the only problem with this, as I tried to do the transfer last week from HWS to HWS with ethernet...is it takes forevah!
Limited time offer
