Hopper remote | SatelliteGuys.US
Hopper remote
sunwshpr
5
texas
I have The Hopper and just purchased a Westinghouse vp 4090 HD TV... the Hopper remote will not recognize the TV,...does anyone have the code for his TV,..or a way to force the Hopper remote to sync?,...
Use the 'Learning' function. The Hopper remote will copy whatever commands you select from the Westinghouse remote. They have to be input one-by-one, though.
http://www.mydish.com/support/40-remote
I did a 2h/3j install yesterday and had 2 westinghouse tv's that programmed without issue. Did you use the on screen remote programming feature? You also have the option of entering the specific manufacturer and model # into the system.
There are no codes for that model built in to the remote, so you'll have to learn as the other poster said.
Yes, you can transfer your settings from one hopper to another via the 40.0 remote.
Convert VIP 222 receiver to a DVR with an external hard drive
More than one remote per H/J
