Hopper/Joey remote double presses | SatelliteGuys.US
Thrashman
23
Pennsylvania
When I program the remote to control an item in learning mode(without a code)
The programmed commands always double press.
Anybody have a fix for this?
Anybody experienced this before?
You are holding the button on the remote you are programming from to long just tap it. I had the same problem. The instructions are misleading, don't hold the button til the hopper remote lights up.
There was a thread on this yesterday that I replied to but I can't find it. (Sometimes I hate our search engine) :)
But yes only hit the button for a split second.
Replacment Hopper Caller ID Failure
Upgrade questions.
