Hopper Bug? | SatelliteGuys.US
Hopper Bug?
Stargazer
16,568
340
Western WV
I was doing a search for movies using themes feature and when I try to search under "Release Date" and select all but "Classic" it will come up with no results but when I select "All" then it comes up with the search results. I have several other selections as well in Themes. Is anybody else having issues doing a search for movies with "Classic" deselected?
This is known issue in the Hopper, but it is listed and Scheduling a Fix. This means the tech have solved the issue and we are waiting for the next update to release that to the receivers.
Reactions: Stargazer
...and hopefully Dish will fix (or if not considered 'broken' at least improve) the search history, too. No more of the pyramid of letters! Understand they want to provide responsive, as-you-type search results which is nice, but we have outlined in this forum a couple of ways you can get the same usability and provide a much better list for search history.
Remote Control Color Button Menu Shortcut List
Fox College Sports games showing up!
