Hopper 3 Noise | SatelliteGuys.US
Hopper 3 Noise
az99
252
49
How noisy are the 3's compared to the old Hoppers? I have had 4 of the old Hoppers. 2 of them make so much noise from the never shutting off HD that they could be heard from 2 rooms away. 1 of the current ones I have is so noisy I put it on a timer to turn off at 11PM so I can sleep. Why don't these power wasting space heaters ever shut down?
Thanx
No noise with mine. It is in our master bedroom and it is very quite. Maybe there is a problem with your hoppers fan. It is couple bucks and easy to replace.
All of my Hoppers (H1, H2, H3) were very quiet. The H3 is even quieter than the others.
Satellite receivers aren't really all that power hungry. About 40 watts, half of which is the LNB and related equipment located on/near the dish.
A whining sound indicates a hard drive on it's way out. A replacement ASAP is indicated.
A fan that runs fast indicates not enough cooling to the unit, or possibly a fault in the receiver itself.
A fan that rattles is grounds to replace the unit also.
Definitely the HD making the noise. Not a whine just like a droning sound. Just like the HD of a computer but 10X louder. I had to fight for hrs. with Dish to get the last noisy one replaced even though I had insurance. I was asking the ? as I will either go to the Hopper 3 or DTV.
Neustar Helps Dish To Target TV Spots
Which package is the Pursuit channel in? Channel 240.
