Right now we have 3 Hopper 2's with sling, all 3 can be watched remotely with different live shows.(kids away at school). How many shows can the Hooper 3 sling out at the same time live?
Thank you, very fast. Dish rep told me today it could do 6 at the same time I think she is confused with other features.One.
Aren't they all? The more I hear about some of the phone reps, the happier I get that I left.Very confused. lol
Has anyone been able to successfully access Dish Anywhere? I'm trying from my home computer and I just shows "loading" continually. The correct receiver number is at the bottom but it appears offline. Any ideas? The H3 is definitely connected to the internet.
hmmmm.... I havent had a chance to try it from outside yet but I was able to access my old equipment from my home computer - I'm not sure what's wrong. Maybe I need to restart my wireless router.I was able to access it using my iPhone yesterday. I even used it to set up a recording and that worked as well. Recorded the 30 for 30 last night.
going to try that right nowTry a different browser. Try deleting the history of you browser. Log out then try to login. Reset your hopper then check the internet connection. Usually these work to fix it. Mine works pretty good.
Well, I'm out of ideas - at least for the moment. This seems to be a computer problem as I just tried connecting with my IPad and it worked just fine. When I use any browser on my desktop computer, the correct receiver ID shows at the bottom of the screen along with "offline" and no "green light" as is normal. I've reset the Hopper, my router and modem, and my computer. I've cleared the browser caches. I'm stumped.going to try that right now
ahh.... OK - I knew about the 100% watched issue as well as space usage but I wasn't sure if enabling "prepare" had the same effect (as far as programs showing watched) from a tablet as it did from the Hopper itself. Thanks!If somebody is streaming something remotely it should show up... The auto prepare was on the old hopper in one of the later updates, but I recommend turning it off as a lesson I just learned last night. First time I have ever hit 100% dvr space, and had t remembered that preparing for transfer creates a second copy, essentially taking twice the room.
Works fine with my Galaxy S6 Android phone... even away from home.Has anyone been able to successfully access Dish Anywhere? I'm trying from my home computer and I just shows "loading" continually. The correct receiver number is at the bottom but it appears offline. Any ideas? The H3 is definitely connected to the internet.
this is an old post - I've since posted that my DA has been working from all my devices - and my PC for at least a week now.Works fine with my Galaxy S6 Android phone... even away from home.
After I disabled "Prepare For Mobile" on the H3, I now get the same message on my iPad/iPhone.I've noticed that as I have used a different Android tablet for the first time with the H3, that as DA loads, I get a pop-up asking if I "want to make all recordings available for transfer". I'm not sure if the tablet is handling preparation or if it's happening at the H3. I've seen this with 3 tablets - I don't remember seeing the message in the past. Last I checked, I had "prepare for transfer" disabled on the H3.
Limited time offer
