I have an HR10 DVR with Tivo. I would love to upgrade to HD, but I am unwilling to give up Tivo. What are the prospects for a Directv-Tivo hardware reunion?
You will need to go to cable to get HD and a Tivo.
I miss file extraction myself. I guess if you like playing musical hard drives the HR20 series is ok but file storage is like the flinstones car and archiving with any order to the files is nearly impossible.There is only one feature that I miss from the TIVO and that is the dual buffers. I really wish Directv would do this with their DVR's.
Besides two active tuners on simultaneously, name one thing that is better about the TiVO when compared to Direct's DVRs.D*'s DVR's are no TIVO. If you like TIVO, you probably won't like D*'s offerings. You can probably get used to them ,even maybe tolerate them eventually, but make no mistake, they are NO TIVO. Better? To some folks, yes. To others,like me, not on your life.
Doesn't really matter though, if you want D*'s HD and you want a DVR, you will get the non-TIVO.
My personal opinion? After trying the new DVR for 9 months, I left D*. It was totally underwhelming to me.
I have no use for VOD,media share, ESATA storage or anything like that. I wanted a rock solid HD-DVR to record and play back programs, with all the functions of a TIVO. The HR20 wasn't it, unfortuantely. Some folks have good luck with them, some don't.
Good luck with your decision. Just remember there is NO TRIAL PERIOD for D*, unless you live in a state that allows it. Once they install it, and you sign for it, it's YOURS for two years. Well, kinda. You still have to send it back should you cancel.And pay the end of contract too.
Its a Win-Win. For directv anyway.![]()
Do not take this wrong because you are more than entitled to loving your tivo software, it is awesome, but typically when that is said "I wont give up tivo" it is because they have never even used the new D* software and assume it will not be any good. Like some of the others here I have 2 SD DVRs with Tivo. Hell the philips directivo I bought some 4 years ago now is still rocking! but the software is very very dated, the guide is dated. D*s new interface is much improved and featurewise is damn good.
Limited time offer
