Hooking up Combo VHS/DVD Recorder to Dish network DVR 522 | SatelliteGuys.US
bikeman
63
Gibraltar Michigan
Hi
I'm wondering what is the best way to do this, RF Cables? S-Video, Composite? right now i got the 522 hooking up to the TV with RF Cable, since the Combo VHS/DVD Recorder only has 1 input/output on the back of it, unless there is another way to do it, and i'm missing that way.
HDTV--Panasonic, Component input availble(2 of them), Input 1,2,3,4,
Panasonic DMRES45 is the model of the combo i think
Hooking up Combo VHS/DVD Recorder to DVR 522
Thanks for replying, if i find a S-Video cable, would the device (VHS/DVD Recorder) need to be on all the time if i hooked it up to output on the DVD-Recorder, and hooked that into the TV.....Also using Component Cables, but i assume cannot record off those from the television, S-Video cables are not much so shouldn't be a problem getting those.
Losing even transponders but signal strength high?
Question about the $6 "lease" fee on my bill
