Hook up of a DVR530 | SatelliteGuys.US
Hook up of a DVR530
markf285
I have an older house with only one coax to the living room. I would like to upgrade my starchoice 505 to the 530. They suggest two seperate cables can you split this cable for your two inputs?
nope.
You need 2 lines from the LNB.
(the only way it would work is if you have the old bandstacked LNB that looked like a flashlight...since you have HD you probably have the quad LNB)
Back to Canada
Bell forgot their receiver...
