Homezone HD | SatelliteGuys.US
Homezone HD
It will be at least a year before I can get U-verse (maybe) so I am looking into Homezone.
Current Homezone is SD only. The service is a neat concept, but I ended up canceling tonight. My biggest complaint was with the functionality of the DVR and Guide - it was really poor. You could sort the 'my recordings' list, you couldn't record anything that you couldn't select in the guide, no search options in the guide other than a blanket search that hit both title and description.
I'm going to try the 622. I know it currently lacks the connectivity features of the Homezone, but at least it's HD and the DVR functionality seems more robust.
An hour ago:
PID: 0854h, ID: S3TC, FW: ACF1, Model: ????
Seems it is new AT&T HD MediaPortal (from 2WIRE) DVR begin beta testing.
[32 MB !]
Scott, can you check ?
E* Installer in Corpus Christi, TX?
Bottom line of EPG partially off screen.
